hope s**t shifter b...
[Closed] hope s**t shifter bike cleaner
[#1455286]
looking at buying some bike cleaner in a 5 litre bulk tub.
looking at either the fenwicks which says you can mix it down to 10/1 whih seems good but hope cleaner looks good value but do you use it neat or can that be dilited like fenwicks.
Posted : 28/03/2010 8:21 pm
I've used the Hope stuff neat and it works OK. Not diluted it though.
I've used Fenwicks at a 9:1 dilution (half a litre in a 5 litre container) and it's not quite as effective as muc of.
Next batch will be stronger.
Posted : 28/03/2010 8:44 pm
Best way to use Sh1t shifter seems to be spray a bit on neat then use sponge in clean water to adgetate the muck and then hose off.
Posted : 28/03/2010 8:51 pm
Buy Fenwiks
Muck Off 5 £/l
Hope Sh1t Shifter 5 £/l
Fenwiks .9 £/l
If your go to a shop that doesn't sell Fenwicks tell them that you would rather buy Fenwicks as you object to spending 6 times as much on a smiler product. I don't think that Muck Off is 6 times better and if the other products are already diluted its bad for the environment.
Posted : 28/03/2010 9:39 pm
fenwicks isnt that cost effective though as using it 9/1 its not very good.
i find i need it nearly 50-50 .
Posted : 29/03/2010 12:37 pm
Fenwicks does me fine at the recommended dilution although I've normally squirted the bike with the Dirtworker prior to cleaning it properly.
I use Fenwicks neat to clean the chain etc.
Posted : 29/03/2010 12:49 pm
I use the Hope stuff, spray it onto the brush / sponge rather than the bike, don't waste as much that way 😉
Posted : 29/03/2010 12:52 pm
In reality - if you rinse the bike with water first and then use a sponge/brushes and some car soap (minus wax) then you don't need Fenwicks etc unless tackling the chain and cassette etc.
No-where else needs de-greasing or washing that "deeply"
Although my cats bought me some cleaner from"green oils" for xmas and it was ace (and smelt nice was biodegradable)
Posted : 29/03/2010 12:54 pm
cheers gets filthy round wet yorkshire
Posted : 29/03/2010 12:56 pm
why not just get gav to make you some up?
Posted : 29/03/2010 12:57 pm
:sorry edit:
lol
Posted : 29/03/2010 1:06 pm
