tried a search but cant find info. anyone the the size of the front and rear bearings in the hope sp am 4 hub?
Drag queens
front = 6804 (x 2), rear 17x32 (x 2) in the hub body, and in the freehub.. 17x28 (x1), 6802 (x2).
thanks brain 😉 did the front today. having alot of trouble finding the hub body ones, even the bearing store was in doubt. why hope did you make it awkard. i only need the 2 main ones and 40 quid for a kit is to much imo. any idea were to get 17 x 32?
They are expensive because they a stainless steel bearings?
think it is that, but the kit is 5 bearings and i only need the 2. front ones cane be picked up anywere for little money
Here:
http://www.bearingboys.co.uk/?catid=1130&att1=&att2=32mm&att3=7mm&att4=&att5=
Fast service.
Hth
Marko
good stuff, will the 3mm diff internal not cause play though? exactly same as front
slight error in my post... should read 6803 (x2) for the freehub,not 6802, sorry
Contact Hope
