So Mrs PPs front Pro2 cracked at the flange. Hope took it back and have replaced the hub body and rebuilt the wheel for free. Yay! 🙂
But I'd just put some of Kaesaes new bearings in the hub when I noticed the crack and I specifically asked (Over the phone and on the warranty return, highlighted in yellow) if they could swap the bearings over to the new shell.
I shall check when I get home, but it looks like they haven't, I'm 95% sure.
Thing is, I said I'd send the shell back on it's own and I'd rebuild the wheel myself, which is why I'm potentially a bit miffed.....
You got a new hub and free wheel build. What kind of pimped up bearings make it worth getting upset about?
removing the bearings damages them so they can not be refitted.
I'd be annoyed. My wife's name is Hope and if she was cracked at...
Best not say any more; don't want a ban 😯
I wouldn't worry about it, they are the same bearings just without the expensive grease I run.
You've missed the point.
Kaesae, sorry, I was looking foreward to seeing how long they lasted!
Still got the rears though 🙂
😆 at psling
As balls of cotton wool says - you cannot remove them once fitted without risking damage
