Hope retainer ring ...
[Closed] Hope retainer ring question
[#6205765]
Quick question for retainer ring owners. Is it just the 30t ring that is threaded? Like this
[url= https://farm6.staticflickr.com/5280/14045330878_dc997e2056_z.jp g" target="_blank">https://farm6.staticflickr.com/5280/14045330878_dc997e2056_z.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/74110581@N03/14045330878/ ]IMG_20140515_111929[/url] by [url= https://www.flickr.com/people/74110581@N03/ ]Jeevester[/url], on Flickr
And do the 32t and above look like this?
[url= https://farm3.staticflickr.com/2898/14232002725_02bea5888b_z.jp g" target="_blank">https://farm3.staticflickr.com/2898/14232002725_02bea5888b_z.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/74110581@N03/14232002725/ ]image[/url] by [url= https://www.flickr.com/people/74110581@N03/ ]Jeevester[/url], on Flickr
Thanks
Posted : 20/05/2014 8:20 pm
 gee
Yes I think so - the 30t has to be as otherwise the bolts wouldn't clear the spider tabs.
Posted : 20/05/2014 8:22 pm
I fitted a 32t yesterday, and it was like your picture shows. Non threaded.
Posted : 20/05/2014 8:28 pm
Thanks. Looks like I'll have to order a 32t instead unless anyone knows where I can get some chainring bolts that are at least 15mm long.
Posted : 20/05/2014 8:40 pm
I've just fitted a 32 no threads also have a brand new 30 don't remember seeing threads on it but can confirm tomorrow if that helps not saying Gee is wrong just don't remember seeing threads on it
Posted : 20/05/2014 8:53 pm
I had a raceface 30T and it was threaded and I now have 32T hope and it is not threaded, exactly like your photos.
Posted : 20/05/2014 9:01 pm
the 30's are threaded as like Gee say's the tabs won't clear the spider. Normal chainring bolts should work though as the threaded parts are designed to replace the inner bolt?
Posted : 20/05/2014 9:02 pm
Thanks etsxteam but that is my 30t in the first pic so no need to confirm. I was wanting to fit the 30t to some xtr cranks but I can't find any bolts long enough to go from the inside of the ring and into the caps on the end of the spider arms. If the ring is like the black one in the second pic then I'm certain the bolts that held the original xtr ring on will do.
[url= https://farm3.staticflickr.com/2928/14045332368_4de7427bef_z.jp g" target="_blank">https://farm3.staticflickr.com/2928/14045332368_4de7427bef_z.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/74110581@N03/14045332368/ ]IMG_20140515_105311[/url] by [url= https://www.flickr.com/people/74110581@N03/ ]Jeevester[/url], on Flickr
Posted : 20/05/2014 9:10 pm
I must be wrong just didn't notice the threads when it arrived Blazin-Saddles explanation makes sense and they must have seen many of them
Posted : 20/05/2014 9:18 pm
Blazing saddles that would be ok if I was bolting from the outside but I need to go the other way as you can see above. It'd look a bit shit otherwise.
[url= https://farm6.staticflickr.com/5116/14045775460_6f2e528733_z.jp g" target="_blank">https://farm6.staticflickr.com/5116/14045775460_6f2e528733_z.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/74110581@N03/14045775460/ ]IMG_20140515_112130[/url] by [url= https://www.flickr.com/people/74110581@N03/ ]Jeevester[/url], on Flickr
Posted : 20/05/2014 9:19 pm
Is this for a single speed or are you just intentionally giving your self a shit chainline in order to stay aesthetic.?
Posted : 20/05/2014 9:28 pm
No its for a 1x10 set up. What do you mean?
Posted : 20/05/2014 9:40 pm
How you have it in your lower photo is how it's designed to work, not sure any 30t rings have clear holes without threads.
Posted : 20/05/2014 9:47 pm
Ended up selling the 30t and getting a 32t. Bolted on with the original xtr bolts from the inside and out into the spider arm caps.
[url= https://farm6.staticflickr.com/5477/14222122996_75589f0c2d_z.jp g" target="_blank">https://farm6.staticflickr.com/5477/14222122996_75589f0c2d_z.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/74110581@N03/14222122996/ ]IMG_20140522_145923[/url] by [url= https://www.flickr.com/people/74110581@N03/ ]Jeevester[/url], on Flickr
Posted : 22/05/2014 5:08 pm
