Hope rear evo hub n...
[Closed] Hope rear evo hub numpty help please!
[#5636418]
Early this morning I wanted to swap my hope evo hub on flows to another bike. Going from 145x12 bolt thru to quick release, found the original adaptors quick release ( or one I think they are) pulled non cassette adaptor out fine, pulled cassette side adaptor out BUT did not remove the cassette first :oops:...............no idea why......so
cassette and freehub body with the pawl all can off.
Now have reinserted body and it engages but adaptor not on and the cassette and freehub fall off.
Have I
a) killed the bloody wheel
b) remedies fixes please
Posted : 26/10/2013 9:45 am
 jimw
It may be that the freehub seal has not been pushed back into hub. Take the cassette off the freehub and ensure the seal is fully back into the hub. I don't think you can do this with cassette on freehub.
Edit: there is a video on you tube
look up hope hub service
Posted : 26/10/2013 9:52 am
You'll need to remove the cassette lockring before you can get the axle adapter off.
Posted : 26/10/2013 10:07 am
that is the embarrassing bit I realise I should have done that???
off to try and reseat the seal
Posted : 26/10/2013 11:45 am
