Hope Pro2 rear axle...
[Closed] Hope Pro2 rear axle conversion q.
[#5567283]
I have 'Hope Pro 11' rear hub, previously run QR.
I bought conversion kit Hub231 to convert it to X12.
The hub still seems to be 135mm wide with the new axle and end caps fitted. I was expecting it to be 142.
Have I done anything wrong or have I got a 135mm 12mm conversion kit in the wrongly labelled bag (does such a thing exist)?
Is it just the end caps that change it from 135mm to 142 or does the axle change too?
I think I should have got end caps that look like this;
mine look like;
[URL= http://i239.photobucket.com/albums/ff167/LukeBurstow/002_zps6bcb7704.jp g" target="_blank">http://i239.photobucket.com/albums/ff167/LukeBurstow/002_zps6bcb7704.jp g"/> [/IMG][/URL]
[URL= http://i239.photobucket.com/albums/ff167/LukeBurstow/001_zps9271bec8.jp g" target="_blank">http://i239.photobucket.com/albums/ff167/LukeBurstow/001_zps9271bec8.jp g"/> [/IMG][/URL]
Posted : 02/10/2013 2:43 pm
If you've got a Pro2, you need the new axle too.. the Pro2 Evo comes with a wider axle to start with and the conversion is just end caps. Does the 12mm axle fit through the axle in the hub at the moment?
Sounds like you've got a 135x12 from what you're saying (or you still need to install the axle).
I'm sure someone with more knowledge will be along shortly.
EDIT - by wider above, I meant larger diameter.. no idea how the width side-to-side varies if at all.
Posted : 02/10/2013 2:48 pm
this is the bag it came in;
[URL= http://i239.photobucket.com/albums/ff167/LukeBurstow/003_zps40bcd268.jp g" target="_blank">http://i239.photobucket.com/albums/ff167/LukeBurstow/003_zps40bcd268.jp g"/> [/IMG][/URL]
the X12 axle fits through but it's only 135mm across the ends of the axle and too narrow for the frame.
Posted : 02/10/2013 2:52 pm
As you suspected, right kit but sadly for you with the wrong end caps.
Posted : 02/10/2013 2:56 pm
so they've put the wrong product in the right bag?
triffic.
Just what I need on my new build 🙁
I have a 'Pro11' hub engraving not 'Pro2' - does that make any difference?
Posted : 02/10/2013 2:58 pm
The hub/axle width should stay the same and only the end caps alter the overall width between 135 and 142. Give hope a quick ring and talk to them, sounds like you just need the correct end caps.
Posted : 02/10/2013 2:59 pm
No the engraving doesn't matter - it's only the Pro II EVO when things were made simpler (same axle - only end caps change and the axle stronger !)
Posted : 02/10/2013 3:03 pm
cheers - have sent CRC an email and will see what they say.
Not sure they'll want the end caps back no they've been fitted? We'll see.
Posted : 02/10/2013 3:04 pm
The photos should be clear to someone who knows the product. Alternatively try a phone call to Hope, most people rate their after sales service (I have found it a mixed bag).
Posted : 02/10/2013 3:06 pm
the end caps in your wheel photos look identical to my 135 x 12mm Pro2 conversion (think my hubs are labelled Pro II as well, of no significance).
Posted : 02/10/2013 3:21 pm
That looks like the old Maxle 135x12 ( http://www.chainreactioncycles.com/hope-pro-2-conversion-kits-12mm-thru-rear/rp-prod21849 ) and not a proper 142x12 (X12) ( http://www.chainreactioncycles.com/hope-pro-2-conversion-kit-x12-rear/rp-prod47535)
Right code on the bag by the looks of it, wrong product in the bag. I hope this isnt a sign of things going down hill at Hope, as I recently had an a standard X12 end cap labelled as XX1/XD X12, which then didnt fit my XD body. LBS sorted it no probs but shouldnt have happened.
Posted : 02/10/2013 3:24 pm
Same happened to me when I bought the correct kit
From bike tart. They had sent the wrong end caps in bag.
A quick call and it was sorted very quickly by them without any more cost to me.
It seems like they're all at it
Posted : 02/10/2013 4:10 pm
I'm sure the part number you need is 345 and 346
Posted : 02/10/2013 4:12 pm
You know when you're building up a new frame and it's got to the exciting part of putting it all together and the anticipation of riding it.
I'm there 🙁
Posted : 02/10/2013 4:14 pm
Sorry that's 445 446
Posted : 02/10/2013 4:15 pm
thanks seanodav - I've emailed CRC hopefully they'll get it turned around quickly.
Posted : 02/10/2013 4:16 pm
