Hi all, a new wheel, well, about 3 months old and its already rough and stiff to turn the axle by hand. Ive never had this with a Hope hub before. Noticed just now as i had it out to check if it had worsened that the end of the hub looks like it's missing a seal.
Cant be sure, and its not that clear here, but im pretty sure a pro2 usually has something filling these areas?
its an evo pro2 if that makes any difference. cheers!
have Pro2s not Evos but looks like the end cap is wrong, every one Ive got regardless of axle standard the end cap has a cover which seals against the hub body over/against the rubber seal you can see.
Nope, that's normal.
That's the new EVO design!
The driveside is also now without 'flange' and everytime I take my cassette off there is a good few mls of water sat in there, even though my bike sits next to a radiator when not in use.
It's perhaps as well they are now fitted with stainless bearings.
Can't quite understand it personally and the old pro2 bearing drifts don't fit now either!
Hmm, well i suppose i should ask Hope what comes next then, its rough and not free running at all now. Had nothing but goodness from Pro2 for years and years so its a odd-un
+1
Had loads of problems with evo at the start - but has been working fine for a month or so... lets see how it fares over the winter 🙄
Had exact same problem on 2 new builds on pro2 evo's sent back to hope and they replaced the bearings and had them back to me the same week! Now they run fine... Probably a bad batch of bearings made it through QC v0v
pro 2 ...
worst
hub
ever
mine is made from cheese it would seem, constantly relacing pawl springs and the freehub is deffo made from cheese...once had one rear bearing fail which destroyed the hub & axle and pretty much and left me riding the nutcracker on a fixie! not great...my burgtecs however have been faultless..
wish i had never bought mine...
I've had loads and never ever had an issue even with my wheel building skillz. Have emailed hope
