I changed the pawl springs last night and was also going to change the pawls but the looked in good condition. Have ran this hub for two years should I change the pawls
If they work and you can see no problems, why would you?
All mine are older than that and I've not even changed the springs which is a shame as I fancy trying the zip tie trick with them.
My Pro2 Evo hub is just coming up to 2yrs old and have done nearly 5000Km on it. Opened up the freewheel last month and didn't notice anything wrong with either springs or pawls. Regreased and rebuilt.
Zip tie trick?
Zip tie trick- a wee bit of ziptie can replace the steel pawl springs. And until recently, worked better 😆
