Hope Pro II crunchi...
[Closed] Hope Pro II crunching noise.
[#1474109]
I'm getting a horrible crunching sort of noise when I put some force onto my pedals. I have changed the bearings in the hub. It's a new SLX mech and cassette and a new chain. In fact it all sits on a new Orange 5 frame.
I have noticed that the freehub outer a nice set of grooves left from previous cassettes. Could this be causing the noise? I don't want to fork out £50 for a new freehub only to find that my current one is fine.
Have I missed something obvious?
Posted : 02/04/2010 10:36 pm
Pedal/bb/pivot bearings
Posted : 02/04/2010 10:37 pm
It does really sound like it's coming from the back of the bike.
Posted : 02/04/2010 10:39 pm
swingarm is a sound box tho
Posted : 02/04/2010 10:40 pm
I was wondering if that might be the case. Every tiny sound is being amplified.
Posted : 02/04/2010 10:42 pm
Its not expensive or difficult to strip the freehub. I can't see how a gouged casette carrier would make graunchy noises unless s the cassette was moving and even then I would expect clicks/ crunches.
Posted : 02/04/2010 10:43 pm
 jimw
when you changed the bearings did you check the pawl springs? My ProII on an Orange 5 started making some odd noises and I found that I had broken the springs one by one until it failed - half way up the Whites climb at Afan
Posted : 02/04/2010 10:44 pm
I did strip and clean the freehub when I replaced the bearings. Paws and springs were fine
Truvativ GXP chainset/BB by any chance?Also worth checking your qr is tight, often a source of strange noises on 5s.
Posted : 02/04/2010 10:52 pm
Hope BB, XT chainset.
Posted : 02/04/2010 10:55 pm
I don't think QR could be any tighter.
Posted : 02/04/2010 11:14 pm
Ah Ha! I think I've sorted the sound out. Did two things before this morning ride.
1) Tightened the QR even tighter!
2) Released that little screw on the rear mech which move the jockey wheels closer to the cassette.
Whatever it was the crunching noise seems to have disapeared for now. Mabey it was the damping effect of 3KG of caked on mud!?!
Feeling very happy.
Posted : 03/04/2010 2:55 pm
