Already asked before but now i have a bit more info.
My rear hub bearings need changing and i'd like to do it myself so i need the tools and the bearings. Ive had a look at the exploded view of the AM4 rear hub and it seems i need 2 17X32X7 bearings for the hub shell.
Does anyone know the code Hope use for these bearings?
Also, does anyone know where to get the tools from? Ive found some on UKBikeStore but it only says they are for the Pro 3 hub and not the AM4 hub.
Cheerd
Sorry. 17x32x8 for the hub shell.
Ditto 🙂
I use sockets on my Hope hubs, one that will take the bearing inside. Taping the axle, plastic hammer, to remove one side then the other easy enough.
These are the tools I use, looks like an inch and a 1/4 to take the bearing which is near enough 32mm
and a 21 for tapping them in 😀
Pro 3 SP AM4 seem to have their own bearings, the ones you're asking for have the code S17328 at £5.85ea, or HUB3AM4R for the complete set at £27.23
Cheers coatesy 😀
