Hope Pro 2 Rear Hub
[Closed] Hope Pro 2 Rear Hub
[#711198]
Strugling to get the cassette off, have read about the prob but i still cant get it off
I have the two small rings off at the moment but just cant get the rest of the cassette off
Hammer Time ??
Andy
Posted : 15/07/2009 10:30 pm
Poke something through the spokes from the non drive side (screwdriver) and tap with hammer. Gently file off the burrs and replace cassette.
Posted : 15/07/2009 10:32 pm
with an XT one (or other one that has the gears mounted to a carrier)
Posted : 15/07/2009 10:38 pm
Have you tried using a chainwhip on each ring to loosen, then pull them off?
Screwdriver and a top with a hammer.....bingo !!!
Will it need a little bit of grease on b4 i pop it all back together ?
Cheers chaps
Posted : 15/07/2009 10:48 pm
No grease, no. I have started putting a thin layer of grease over the outer surface of the outer bearing in the freehub though
- pull the dust cap/seal bit off that sits in the dropout.
Posted : 15/07/2009 10:59 pm
Thanks again for the help, sorry for all the questions just getting used to tinkering about with my new toy 🙂
Andy
Posted : 15/07/2009 11:16 pm
