Hope pro 2 hub ques...
[Closed] Hope pro 2 hub question
[#3158630]
I have just converted rear hub to 10mm bolt through, but when I nip up the bolts the wheel doesn't spin as good (as if the bolts are tightening the free hub) ?
Anyone else experienced this?
Posted : 18/09/2011 8:14 am
did you remember the freehub spacer ?
part 9 bottom pic iirc
Posted : 18/09/2011 8:30 am
I'am 95% sure it's in but I will double check
Ps do you know if I can take our the bolts and use a 10mm q/r skewer?
Posted : 18/09/2011 8:41 am
Either a missing spacer, or the freehub seal isn't seated correctly, presuming your bearings are all ok.
Posted : 18/09/2011 11:07 am
usually missing free hub washer they jump off and hide when you lease expect it, I think its a different axle if you want to use a 10mm skewer.
Posted : 18/09/2011 11:27 am
10mm bolt-up and 10mm bold-through(skewer) are different axles.
Posted : 18/09/2011 1:27 pm
 Olly
if the bearing isnt seated completly, it will also cause this.
If none of the spacer fiddling works, take a hammer to the bearing you took out to get the new axel in/out.
one hearty SMACK sorted mine.
Posted : 18/09/2011 2:52 pm
