any ideas guys.
i need to replace the bearings on my pro2 rear.
spacers are off but for the love of god the free hub will not come off.
we,ve had two of us on it pulling but no joy.
You have a couple of options,put the rear block back on and use this to pull the whole assembley off the Hub with your hands.
Or you can remove the seal and Tap the hub carrier off through the hub from the opposite side,but use something over the end to avoid damaging the alloy axle.warm everything up a bit with a heatgun/hairdryer helps too.
Be carefull not to loose the narrow spacer between the inner wheel bearing and freehub carrier.
hth
gavgas so use a small screwdriver to get the freehub seal out the hit the axle from the other side
found the answer on you tube...and it,s the guy off here.
Kaesae.the man,s a genius..
