My 18month old Hope Pro 2 Evo Rear Hub has developed 2-3mm of for / aft play, noticeable with the rear brake applied (i.e. the bike will rock forward / backwards slightly), or when checking the cassette with the wheel off - any ideas?
The bearings feel fine and appeared ok when I took the freehub off to check. The cassette is fitted correctly and there is no side to side play.
Any help would be appreciated,
Thanks.
Posted : 08/08/2013 10:16 am
Snapped axle?
Posted : 08/08/2013 10:47 am
Pad float/play or loose disc/floating disc rivets. Mine was the rivets
Posted : 08/08/2013 11:03 am
Adsh, will check that.
Posted : 08/08/2013 11:05 am
Loose disc/floating disc rivets. Mine was the rivets.
It was this, had a spare disc in the shed so all sorted 😀
Cheers adsh
Posted : 08/08/2013 1:13 pm
Cool - mine's small enough and on the rear so I've left it.
Posted : 08/08/2013 2:40 pm
