Is there such a thing as an adaptor for the Hope Pro 2 evo hubs so that I can use them with the 9mm superstar front qr skewers. These are the oversize ones. I'm rather confused because what is described as the Hope 9mm adapters for qr actually only seems to take a standard 5mm skewer.
Is this what you mean?
Looks like they might be the ones but I ordered something of that description and when it arrived it was only for 5mm dia skewers. Those ones look larger tho so more promising....
Aren't Hope just great! I can still buy parts for my 15 year old (ish) pro 2 hubs to make them 12mm compatible. I know they're pricy and not super light but I like them.
Its the 9mm front and 10mm for rear you want. Anything that says QR will be too small. if you are going for the rear too and you dont take the back wheel off a lot the bolt through axle is good.
The ones linked above are the right thing.
Defo available as im using one as you describe with a superstar lever on my onone rigid forks
I’ve got a set of those in my toolbox you can have for postage. May need a new o ring.
Edit sorry mine are the ones for a standard qr skewer not the 9mm bolt through
I have some for a 9mm thru axle that you can have for postage a a drop in a charity box. Pm me.
Thanks everyone. It's making a bit more sense now. I've been confused by the references to 9mm QR caps which are in actual fact 5mm QR. Have sent a Pm to Shackleton....
