hope pro 2 conversi...
[Closed] hope pro 2 conversion ?
[#4685964]
Anyone know if i can convert a standard Hope pro 2 hub to 142x12mm rear hub?
Hence new frame trek remedy
Posted : 27/12/2012 2:51 pm
Yep, just needs one of these:
http://www.ukbikestore.co.uk/wl.aspx?3&req=0-HUB231
Though, you may run into the common axle-snapping issue, the walls of the 12mm axle are too thin. Another option is to upgrade the hub internals to Pro 2 Evo, which have a fit-for-purpose axle. Much more expensive though.
Posted : 27/12/2012 2:56 pm
