Hope pick n mix hea...
[Closed] Hope pick n mix heasets
 Earl
[#6490964]
Am I understanding this right? Using upper cup 2 and lower cup h I can use a tapered fork instead of my 1 1/8th one? (with a small inc in stack height so front end will be slightly slacker)
[url= http://cdn.hopetechnology.netdna-cdn.com/wp-content/uploads/2014/03/HOPE-HEADSET-FITTING-CHART.pdf ]http://cdn.hopetechnology.netdna-cdn.com/wp-content/uploads/2014/03/HOPE-HEADSET-FITTING-CHART.pdf[/url]
Posted : 17/09/2014 7:25 pm
Correct! (given that you have a 44 mm ID head tube). I ran that exact combo on my Singular Buzzard with a tapered steerer Revelation.
/Johan
Posted : 17/09/2014 7:29 pm
Or, can you just use the H lower and your normal upper ??.
Posted : 17/09/2014 9:36 pm
