Hope PF41 BB and Ra...
[Closed] Hope PF41 BB and Raceface Cinch crank Help
[#10249063]
Evening all
In need of some help please. I've got a 2018 YT capra, with a 30mm race face turbine cinch crankset.
It's a PF41 x 92mm Bottom bracket shell, so after doing some research on here and how little time the race face BB lasted, I opted for a Hope PF41 bottom bracket.
Anyway, hoping to ride the weekend, I've fitted the two bearings into the BB shell, and according to a Hope PDF I acquired, it just requires the two thin washers outside of each bearing for a 92mm bb shell..
When the cranks have been installed, there is a 3-4mm gap on the non drive side, which seems too much for me, this can only just about be taken out with the preload adjuster on the crank arm as there is only just enough threads.
Is this normal and acceptable?
Thanks alot guys.
Posted : 28/09/2018 9:09 pm
On my Jeffsy I had to add a spacer on the DS side from memory mate..... I had one laying around, it didn't come with the kit......
Posted : 28/09/2018 9:23 pm
i had this with my Tues. i spoke to Hopr and they sent me some extra spacers, but even then it was barely enough. i think i bought some Wheels MFG spacers to take the slack out. Hope werent really very helpful when i explained again....
Posted : 28/09/2018 9:27 pm
I've got three bikes with Hope BSA30 bottom brackets and Cinch Turbine cranks. Each time I've added a couple of Wheels Manufacturing bottom bracket spacers - worked a treat.
Posted : 28/09/2018 9:47 pm
Thanks so much guys for the quick replies. Massive help!
I've just stuck my chain back on, and it's catching on the e13 chain device when at the top of the eagle cassette, which it never did before... there is a 2.5mm spacer supplied, is it ok to fit this drive side then?
Thanks again
Posted : 28/09/2018 9:51 pm
On my Jeffsy I had to add a spacer on the DS side from memory mate….. I had one laying around, it didn’t come with the kit……
Did you put that under the bearing when installing in the frame mate? Or did it go on the outside?
Posted : 28/09/2018 10:31 pm
I had to fit shims to the last one I fitted, same bike and BB, I just used spindle shims I had lying about.
Posted : 28/09/2018 11:53 pm
