Hope Mono Minis que...
[Closed] Hope Mono Minis question
[#485578]
Mate has a front Mono Mini (circa 2007) [b]IS[/b] mount - outer edge of disc fouls the caliper. I'm thinking the disc isn't a Hope and therefore the wrong size.
What size discs should they be?
thanks.
Posted : 20/04/2009 9:42 am
 juan
what caliper number?
IIRC it's 160/180/2000 and you may have a 203 as well.
Posted : 20/04/2009 9:52 am
[i]what caliper number?[/i]
As usual I'm trying to answer remote questions without access to the bits, so don't know.
It looks like a 180/185 from the pic, so maybe should have a 180.
Posted : 20/04/2009 10:03 am
 juan
well if it's the mono mini (black) it's 180. If it's the mini it's 185 they use a wavy disk. It's doable to use a 185mm wavy into a 180 mono caliper, it take a little bit of grinding not much just a little bit due to the difference in the depth of the caliper;
Posted : 20/04/2009 10:19 am
Definitely Mono Mini.
Grind the disc or the caliper? 🙂
Posted : 20/04/2009 10:24 am
 juan
caliper is easiest disk is safest
Went for the disk 😉
Posted : 20/04/2009 10:38 am
Yep, thats what I thought you'd say...
How's things in France anyway?
Posted : 20/04/2009 11:14 am
 juan
France sucks, not tiem for biking no time for climbing I just miss good old UK to be honest. Weather is crap yes, food is a bit of a struggle yes, but people are way less prone to judge and much nicer...
Posted : 20/04/2009 11:16 am
Sounds like you're working too hard... see you at the BBB?
Posted : 20/04/2009 11:20 am
