Hope Mono Mini Ques...
[Closed] Hope Mono Mini Questions
[#3554649]
Just looking to freshen up the bolt sets on some Mono Minis and discs.
Would anyone tell me the sizes for: Rotor bolts are they the M5 by 8mm? Are the tapered head ones best bet here? and IS mounts Are they the M6 x18? What's the most practical shim size to have in the box?
What's best? Torx or Allen Key? And then to tighten: Common Sense and thread lock Vs Torque wrench set? Is Threadlock a must?
If I renew the hoses too, do you reckon the olives and connectors will all be re useable easily?
To get all the hoses matching ie brakes gears whats the approx length for a 16" Hardtail? FB, RB, Rear Derailer only for 1x9. Is the SS braided 6mm (is it?) a bit overkill on Minis really? Will the Hydraulic hose also take the cable for rear mech?
Posted : 11/01/2012 7:27 pm
