Hope mono mini help...
[Closed] Hope mono mini help!
[#270179]
I need a little help with my Hope minis. It seems that one piston moves much further and returns much more readily than the other. I have tried holding the smooth one in and pumping the brake, and the slower one does come out and return, but just doesnt seem to move as far or as quick than the other. All this means that the slow one tends to remain in contact with the disk a little, albieit gently, it still slows me down.
Any ideas welcome
S
Posted : 03/02/2009 2:08 pm
They could probably do with a gentle clean & lube
Remove the pads & push the pistons out - not far enough for them to pop out
Apply some brake fluid with a cotton bud & cycle the pistons in & out a few times
Posted : 03/02/2009 2:12 pm
Pretty much what uplink said, but get a brush in there first to remove all the brake crud etc before lubing. You will probably need to do the lube, pump, clean cycle a few times. And there is no reason to use brake fluid - I have always used ordinary oil as by definition there is no exchange of fluids past the seal
Posted : 03/02/2009 2:26 pm
Any sign of leakage? a full seal and piston service is pretty cheap and straight forward.
Posted : 03/02/2009 2:48 pm
I'd be wary of using oil as a lube, if it turns out to be mineral based you can kiss goodbye to your seals.
Posted : 04/02/2009 12:15 am
May be worth checking out the Hope website
http://www.hopegb.com/page_mep_force_39.html
Had the same but not since following vid 🙂
Posted : 04/02/2009 12:29 am
