Hope Mono Mini Help
[Closed] Hope Mono Mini Help
[#1603677]
Due to crash damage I need to replace one of the master cylinder caps on my 2008 Hope Mono Mini brakes. I have a replacement cap, but before I bodge anything :|... any advice on how to do this? Is it a case of just unscrewing the old one and popping the new one on there?
Cheers in adavnce.
Posted : 13/05/2010 12:16 pm
yes simple as that- do not overtighten the screws holding it on - they only need to be nipped up
Posted : 13/05/2010 12:19 pm
What he^^^^said - if the screws are the domed hex ones the amount of Allen key that engages is tiny and very easy to round out the bolt head.
Posted : 13/05/2010 12:21 pm
Cheers guys, i'll be very careful then 😯
Posted : 13/05/2010 12:31 pm
WHat they said about the bolts! And is the diaphragm damaged as well?
If they don;t need bleeding then you should get away with just topping up with fluid and refitting the diaphragm and cap... [url= http://www.hopegb.com/page_mep_force_35.html ]good stuff from the Hope website on rolling the diaphragm on[/url].
Posted : 13/05/2010 12:33 pm
Does the 2008 not use a T10 Torx fitting?
Posted : 13/05/2010 12:35 pm
Sorted 😀
Yes, I used a T10 Torx key for the bolts. Both rubber diaphragms were fully intact so it was just a case of carefully lifting off the old caps and replacing them with the new ones.
Posted : 13/05/2010 4:17 pm
