if that makes sense! I put my bike away after a ride and when i get it out next time its like they need bleeding after about 15 mins of use they seem to come back again. The bike is stored at 45 degrees but I dont touch the brakes so dont think this is an issue. No sign of leaks and have bled them - not sure whatelse to try!
My front one was rubbish on Saturday. Worked ok after pouring some water on it, for a while, then went off again...
Are you brimming the reservoir and then 'rolling the diaphragm' on to expel any air bubbles?
No I havent been could there still be air in the system then? I never used to find a problem with my shimano ones but maybe these are more sensitive
Robbo,
Can you get a brake if you pump the lever? If so you have got air in there somewhere.
Time for another bleed then!! Cheers
If you can't be bothered with a proper bleed try this.
Store it with the reservoir at the highest point, tape the lever back to the bar overnight. The air bubbles should rise to the top. In the morning, remove the tape, take off the cap and top up the fluid. Simples!
And bleeding them without pushing the pistons all the way back seems better too.
