Hope mono mini brak...
[Closed] Hope mono mini brake sizing
[#1559916]
Just bought a hope mono mini brake off flea bay witha no3 caliper. The guy had it set up on the rear and sold without a rotor. I've decided to put it on the front as the lever is for the front. The problem is rotor size as i've tried a 160mm rotor and this skims about half of the pads and a 180mm rotor is too big?? Which size rotor do i use for this caliper, any help would be good.
Thanks
Posted : 29/04/2010 10:56 pm
Think you need the (H adapter) for the 180 mm rotor, that wot i use, I think thats wot you need 🙂
Posted : 29/04/2010 11:05 pm
no. 3 caliper should be 160 rear or 180 front disc IIRC. No adaptor required as its an is mount
Posted : 29/04/2010 11:35 pm
