Hope lights with Ho...
[Closed] Hope lights with Hope stem
[#784342]
I understand you can mount Hope lights on the front of a Hope Stem if you get the appropriate parts. Done a quick search on line and its not clear what bits are needed. I have a set of '09 Vision 2 lights. Is the stem mount worth having, i.e does it all work ok, and is the light unit then fixed on the stem (not QR)?
Ta
Posted : 14/08/2009 1:21 pm
The light is bolted, the battery is QR
Posted : 14/08/2009 1:30 pm
Cheers James. Any experience of using it, just trying to work out if its worth getting a stem. Just like the idea of integrating the light unit and stem.
Posted : 14/08/2009 2:11 pm
i have an 08 (maybe 07) 2LED and i think that the mount is miles better than the QR one you get with the new versions. it's a proper cnc'd bracket that bolts on to your bar and is super-sturdy as apposed to the foam pads that wobble around on the QR version. so in my view it would be a good purchase. i think all you need is a front plate to replace the normal one on a hope stem and the light unit bolts directly on to that.
Posted : 14/08/2009 2:17 pm
I got rid of mine a couple of years ago and changed to USE. It's a neat solution if you have one bike, bear in mind if you run a short stem you will need the other battery that mounts widthways.
Posted : 14/08/2009 2:19 pm
Just be careful the battery doesn't ding the top tube when you turn the bars right round.
Posted : 14/08/2009 4:34 pm
