Hope levers
[Closed] Hope levers
[#4366604]
Does anyone know if the Hope Mini/M4 levers from the silver & black Mini/M4 will fit the original Mono Mini/M4 black & gold models?
My Mono M4 levers are wearing where the brass barrel is leading to a lot of play.
Posted : 16/09/2012 10:01 am
Not sure, if you mean early Mini and then mono mini, then I think they are the same as they use the same lever but diff caliper.
double check I got the right ones
http://www.hopetech.com/page.aspx?itemID=SPG131
mono mini, and Mini.
Mini 2007 which have diff levers
http://www.hopetech.com/webtop/modules/_repository/documents/mini2007mcylexploded.pdf
Posted : 16/09/2012 10:55 am
Posted : 16/09/2012 11:04 am
Just phone Hope,.they will probably get you to post them off to them and fix them for free.
Posted : 16/09/2012 11:20 am
Interesting. All the related parts have common part numbers but the lever blades have different numbers. I think there's a good chance they'd fit but they might feel slightly different.
Posted : 16/09/2012 11:30 am
ruscle - Member
Might just try that tomorrow...Ta
Posted : 16/09/2012 12:28 pm
The lever blades aren't interchangeable, i'd have swapped mine with one we had lying around otherwise.
Posted : 16/09/2012 12:56 pm
Bugger. Tops off a shite day and a half, that does.
Posted : 16/09/2012 11:55 pm
 igm
Ring Hope like you were told to.
Posted : 17/09/2012 7:57 am
 Leku
teeth - ygm
Posted : 17/09/2012 10:09 am
