Hope Hubs - differe...
[Closed] Hope Hubs - different length rotor bolts?
[#2092834]
Just tried fitting some rotor bolts to a hope hub and they wouldn't tighte down. One of the bloody things sheered as well.
Took them all out (mius the sheered ones) and tried a different set that again didn't tighten down.
Do hope hubs use a shorter rotor bolt?
Posted : 16/10/2010 11:16 am
I recall an old hope xc had the end of the bolt holes blanked off, at least until i used slightly longer (shimano iirc) bolts, too much threadlock and a power drill and blew them out. Doh!
Posted : 16/10/2010 11:26 am
That is what I have.
Any idea what size bolt I needthen?Or should I just put a couple of shims under the current ones?
Posted : 16/10/2010 12:55 pm
Washers. Sorry i forgot to come back to this thread.
Posted : 31/10/2010 5:44 pm
If the holes are blind - I'd just shorten the screws to suit
Posted : 31/10/2010 6:13 pm
Some Hope hubs are drilled all the way thru' but the threads are not tapped all the way thru' the boss. I have seen the bosses split where the owner has forced a too longer bolt into the boss. Best cut the bolts or get a tap & cut the thread full depth.
Posted : 31/10/2010 7:20 pm
