Hope hub advice hel...
[Closed] Hope hub advice help please!!
[#5975507]
Hi all I'm new to the forum and have a question if I may?
I bought a hope xc hub on eBay it's in good nic and working order but it has a 12mm bolt through axle and I wondered if there is any where or any way you can change it to a qr it's 135mm wide anyone shed some light would be much appreciated cheers
Posted : 19/02/2014 8:42 pm
It won't be an XC if it has a bolt through axle, possibly a BULB if it looks similar. If it is, you'll need a new axle and end caps(possbly new bearings too, from a niggling thought in the back of my mind), check Hope's tech section on their site for details.
Edit- if it is a Bulb, you'll need a 6001-2rs bearing, an axle, and spacers, part no.s HUB208,HUB411,& HUB407, unable to get onto their dealer site at the moment to check if they're still available.
Posted : 19/02/2014 9:16 pm
Pictures of a Bulb hub and how to identify it.
[i]"The Bulb hub is identifiable by the letters BL etched in small text underneath the Hope logo on the main hub body."[/i]
http://www.hopetech.com/page.aspx?itemID=SPG163
Diagram showing what parts you need to swap from 12mm to QR
Posted : 19/02/2014 10:21 pm
Finally got the dealer site to load, all parts still listed as available, but not a guarantee as obsolete parts don't always get deleted.
Posted : 19/02/2014 10:23 pm
Hi guys thanks for the help it has a BL code on it it was advertised as xc I will get on to hope and try and track the bits down
Posted : 19/02/2014 10:47 pm
