Hope hose clamp qu...
[Closed] Hope hose clamp question
 robh
[#3654356]
So I've got some new hose clamps and some that I've had sat around for a while, both 5mm, the new ones have come with 2 different sized brass washers, for the banjo 2 large to seal banjo to the hex nut and for the straight cnnector one large for connector to master cylinder, but each of the bajo and straight connectors also have a small brass washer that my old connectors did not have.
Question is do I need the small washers as the old connectors are the same in every other way but don't have them, if I do need them where do they go and where can I get soem spares for my older connectors? Can't see any on CRC.
Posted : 07/02/2012 10:33 pm
I bought some here 10 in a pack for a quid, + postage
http://www.sjscycles.co.uk/hope-copper-washer-%28suits-brass-insert%29-10-pack-prod25822/
Posted : 07/02/2012 11:31 pm
 robh
Are they not the larger ones? I've got them it's the smaller ones that were in the packet that I've no idea where they do or whether I actually need them as my older (still 5mm) connectors did not have them.
Can't find an exploded picture on the net of a 5mm connector to highlight the two sized washers or see where they would go.
Posted : 08/02/2012 11:03 am
 robh
Are the smaller washers something to do with newer brakes, the mono minis were probably the latest brakes when I bought the old connectors.
Posted : 08/02/2012 2:57 pm
I bought these for my Tech 4's they go onto the brass bit that goes into the hose and then screws into the lever assy , goes between the lever assy and the brass bit. 😀
Posted : 08/02/2012 4:41 pm
