Hope hoops- are the...
[Closed] Hope hoops- are they all EVO hubs?
[#8373866]
Hope hoops- are they all Pro2 EVO hubs?
or are some the older Pro2?
If so, how do you tell the difference?
Are the markings the same?
Posted : 22/02/2017 10:44 am
Evo says evo, depends what rims as for age, also the 142 conversion makes it the same as the evo.
Posted : 22/02/2017 10:46 am
so if it doesnt say EVO, its not EVO?
Posted : 22/02/2017 10:50 am
I thought I saw some hubs claiming to be EVO, but only marked as hope hoops, so I want to know
Posted : 22/02/2017 11:11 am
The hub shells are the same.
The internals differed I seem to recall it's about taking a 12mm axle in the rear.
If it says evo it was born evo
If can be exactly the same if it's had the bearings and axle swapped/fitted.
Posted : 22/02/2017 11:14 am
Were there not differences in bearings as in the move to stainless steal? I believe as above you can convert a Pro2 to an evo, could be wrong though
Posted : 22/02/2017 11:19 am
Full tech drawings etc on the hope site I think.
Posted : 22/02/2017 11:22 am
The first versions of the hoop wheels used pro2 hubs, when the evo came out they changed to use that instead.
The pro2 rear has the same body but with a different axle, freehub and bearings. You can convert a pro 2 to an evo by changing all the parts. If it doesn't say evo on it look at the shape of the end caps as this will tell you what hub it is. The original pro 2 and evo can't do 11 speed, only the evo 40t or pro 4 can do this.
The front pro2 and evo are the same.
Posted : 22/02/2017 11:25 am
wut? Do you mean SRAM or shimano 11 speed?
Posted : 22/02/2017 11:32 am
Running sram 11 on an original pro ii with 142 conversion. The pro ii evo will also take an xd freehub.
Posted : 22/02/2017 11:35 am
hope moved the drive side flange inboard a bit on the pro 4 and pro 2 evo 40t for 11 speed as you have to fit a spacer to run 10speed. Maybe this is just for shimnao 11 speed if mikes running sram fine
Posted : 22/02/2017 11:38 am
Er what? Pro 2 evo is dame shell as the pro 2. Your not thinking road are you? No spacers needed for mtb cassette.
Posted : 22/02/2017 11:40 am
Running 11-speed Shimano M8000 cassette on original Pro2/DT5.1 hoops no problem here
Posted : 22/02/2017 12:03 pm
Pro2 rear works 11 speed M8000 as QR and 142x12mm on mine. Steel axle replacement from Hope as the 142 axle is poor in alloy. Both the 142 end caps and QR end caps work on the axle.
Posted : 22/02/2017 12:05 pm
just called hope and they said all hoops had evo hubs
Posted : 22/02/2017 12:31 pm
What do you actually mean by hoops? They called their original factory built wheels hoops ( I have some nice ex display ones) do you mean on their rims?
Posted : 22/02/2017 12:33 pm
I mean their hubs with hope hoops logo on them
Posted : 22/02/2017 12:45 pm
Right probably some confusion in there as they were selling wheel builds without that on the hubs for a while (and calling them hoops)
Posted : 22/02/2017 12:47 pm
Yes that's what I said the pro2 and pro2 Evo have the same shell, it's the pro 2 Evo 40T has a different hub shell.
I have two pairs of pro2 hubs with the hoop logo on them so can vouch for the m being sold
My pro 4 rear hub needs a spacer to run a 10 speed cassette. Without it the cassette is loose
Posted : 22/02/2017 1:48 pm
This might help
http://www.hopetech.com/11-speed-compatibility/
Seems the 11 speed thing I mentioned is only if you want to run a road cassette. I guess hope did that for cross bikes.
Posted : 22/02/2017 1:51 pm
so theres no way I can be sure without seeing the end caps?
Posted : 22/02/2017 2:16 pm
My front wheel is a Flow on Pro2, but hub is etched 'Hope Hoops'. Not sure there is any actual difference between Pro2 and Pro2 Evo fronts, anyway.
No 'Hope Hoops' etching on rear.
Posted : 22/02/2017 2:21 pm
well I've got a set of wheels that says differently. 'Hope Hoops' was their name for factory builds and those started with Pro2 hubs.
And as above the 11 speed issue is for road cassettes and is relevant to those of us building CX/road disc wheels.
Posted : 22/02/2017 3:23 pm
crashtest monkey, you're right, Hope was wrong
Posted : 01/03/2017 11:43 am
