Hope hoops
[Closed] Hope hoops
 J273
[#3345237]
Does anyone know where the best place is to buy some hope hoops atm?
Looking for some stans flows white with red hubs.
Anyone know any good deals around ?
Thanks
Posted : 12/11/2011 8:43 pm
Not looked recently but got some Pro 3SP's with stans from Winstanleys V CHEAP 12 months ago
Posted : 12/11/2011 8:47 pm
 J273
They only do all black as far as i can see.
Ive found them here http://www.moonglu.com/shop/hope-hoops-pro-2-on-white-stans-flow-rims/
Which is exactly what im after - Can anyone find cheaper than that?
Posted : 12/11/2011 9:08 pm
"Hope Hoops" only come in black - Moonglu build their own to the same spec as Hope - Merlin might do you similar (Use code VIP10 for 19% off) for cheaper, but I doubt it. CRC too.
Posted : 12/11/2011 9:17 pm
Sorry, 10%, not 19
 J273
Ahh thanks didn't realize that.
Ill check merlins out.
Posted : 12/11/2011 9:20 pm
[url= http://www.hopetech.com/page.aspx?itemid=SPG244&tab=specification ]That's not correct.[/url]
Andy
Posted : 12/11/2011 9:25 pm
[url= http://www.progressive-bikes.co.uk/department/wheels/ ]Hope hoop wheels [/url] 🙂
Posted : 12/11/2011 9:44 pm
Winstanley are a good price
[url= http://www.winstanleysbikes.co.uk/product/41996/Hope_Pro_2_EVO_No_Tubes_Flow_Standard_Lacing_Front_Wheel ]Front £104[/url]
[url= http://www.winstanleysbikes.co.uk/product/40400/Hope_Pro_2_EVO_No_Tubes_Flow_Standard_Lacing_Rear_Wheel ]Rear £176[/url]
but black hubs white rims
Posted : 12/11/2011 9:51 pm
Looks like they only come in black according to the link?
Posted : 12/11/2011 9:53 pm
Bottom right of the picture it says "Flow Rims now available in white"
Andy
Posted : 12/11/2011 9:56 pm
Ahh the rims not the hubs, my mistake.
Posted : 12/11/2011 10:02 pm
To be fair, I'd not read the OP properly. While you can get white rims, the hubs only come in black unless you want custom (I got a DT XRC 400 on a 28h Pro II made up by the LBS for less than CRC are selling the Hope Hoop rear for, so even for a Stan's rim it shouldn't be frantically more expensive).
Andy
Posted : 12/11/2011 10:08 pm
That's what I thought. I got 355's with gold hubs all badged as hope hoops through my LBS, however they do have a very close relationship with Hope.
Posted : 12/11/2011 10:14 pm
Lex's mountainbike heven have em.
Posted : 12/11/2011 10:44 pm
Hope 'Pro Shops' or whatever they're called can get coloured hubs on Hope Hoops.
Posted : 12/11/2011 10:46 pm
A small point that may or may not bother you - white Flows weigh 40g more each.
Posted : 12/11/2011 10:53 pm
You can get coloured rims and hubs, but not at normal Hoop prices. Expect to pay around £350.
Posted : 12/11/2011 11:10 pm
gravity-slave - Member
Really? Blimey. I've been wanting a set of white ones for a while to replace the black ones on the Hemlock, but now I won't.
God, that's really pathetic :mrgreen:
Posted : 12/11/2011 11:11 pm
Yup, from Stan's own site:
http://www.notubes.com/Flow-Rims-C22.aspx
Black - 470g
White - 510g
Every little helps 😉
Posted : 12/11/2011 11:30 pm
Certainly couldn't abide my 36lb bike having 80 grams more paint on the rims :mrgreen:
Posted : 12/11/2011 11:51 pm
 J273
Jeez wouldn't of thought that......think im still going to go white though and order from moonglu as i cant find any cheaper than that. (£305)
Are the stans flows about as good as it gets rim for strength/weight? for the money without spending £££££
I currently use mavic 823 rims which are 666g real weight according to weight weenies and are total overkill for what i use - bought them used as i wanted a decent UST rim but now wanting something a little lighter now.
Are the flows worth the extra over say Mavic en521's ....which according to weight weenies weight 531g.
Ive got a spare PRO2/EN521 rear wheel which i planned on pairing with another for the front (£97 from merlins) but im thinking now just to sell the three wheels i have and go for the flows.
Just undecided on whether to pay the extra for the flows or go cheaper with the EN521's which will be alot cheaper as i already have the rear.
Posted : 12/11/2011 11:56 pm
go for the straight pull evo's lighter and tighter than standard evo's
but only in black, any hope tech shops should get u coloured hubs at no extra cost but hope will only do them for tech shops.
Posted : 12/11/2011 11:57 pm
J273 - Member
Pretty hard question tbh. But mine have proved tough as nails despite the low weight, and obviously tubeless ready too. Not going to say whether they're stronger or weaker than my 721s, don't honestly know, but they've shrugged off blows in much the same way.
Not sure I'd buy the rims seperately but in a full Hoops/equivalent build they work out much better value.
Posted : 13/11/2011 12:12 am
They are both listed as 28mm rims. Flows are pretty good and easy to set up tubeless but they ding easier than Mavics and lack the eyelets so potentially weaker around the nipple.
I'd probably go with the 521's unless you want to go tubeless or save weight (doesn't look like you do).
Flows are expensive on their own but Flows on a Hoop work out as a relative 'bargain'.
Posted : 13/11/2011 12:15 am
 J273
Im only really going for the flows to save weight as the 823's are FR/AM rims really and weighty.
With the flows allowing me to go tubeless thats whats drawing me towards the flows rather than EN521's
Hmm what to do - Buy another en521 for the front costing me under a ton and then sell me 823 wheelset or sell the lot and go for a brand new pair of flows.
As said though the only reason is to save the weight - wouldn't mind the white rims though 🙂
Posted : 13/11/2011 12:26 am
The black ones are.
Posted : 13/11/2011 11:24 am
I've bought wheels built by Merlin before, I had to re-tension them before I even rode them. Whereas, I will only buy wheels from Moonglu now. I've had 2 sets of the Hope/Stans from Neil (Moonglu) and they're brilliant (including some pretty ugly/big hits in the Alps). Bit of a no-brainer for me now.
Posted : 13/11/2011 11:34 am
when i bought my hope hoops last year black was the only option. went for straight pull pro 2 on en 521s, still running well. even use them for downhill on my patriot at cwmcarn as i havnt bought its own set of wheels yet..
Posted : 13/11/2011 11:57 am
 J273
Think ive decided on the flow rather than EN521's with them allowing me to go tubeless.
Now white or black????...Thinking black now as white might be a little overkill - Thoughts?
Posted : 13/11/2011 12:39 pm
WHITE,,,,,
Posted : 13/11/2011 5:18 pm
1) White is pimp
2) The white would definitely match the white highlights on your frame.
DO IT!!!
Posted : 13/11/2011 5:51 pm
 J273
Ive just found this on youtube.....What do you guys think?
Posted : 13/11/2011 6:12 pm
If its just white rims you need with black hubs we can do them for the price advertised here, [url= http://www.progressive-bikes.co.uk/product/hope_hoops_front_and_reard_evo_hubs_with_flow_rims/ ]Hope Hoops[/url]
Posted : 13/11/2011 6:17 pm
white on red for you I think...
Posted : 13/11/2011 6:28 pm
buy the rims seperate get them powdercoated then built up or buy my hope pro 2 hubs on mavic 321s
Posted : 13/11/2011 6:48 pm
 J273
Still undecided....Going to order today.
Are the white worth the extra 80g the pair over the black?
Posted : 15/11/2011 12:36 pm
BLACK
You'll ruin that bike with hideous white rims
Posted : 15/11/2011 12:42 pm
Not in my opinion.
Posted : 15/11/2011 1:32 pm
black on the spec. for my money.
Posted : 15/11/2011 1:33 pm
Most importantly, you must go for red hubs with those floating rotors - they look ace together
Posted : 15/11/2011 1:35 pm
 D0NK
not going to comment on the inane "do my collars match my cuffs" but the 40g difference isnt the only downside to white rims. My olympics* are getting corosion where the paint has bubbled. Whether thats down to rubbish paint job I don't know but not had any corrocion trouble with the black anodised rims.
*white ones were on offer at the time.
Posted : 15/11/2011 1:42 pm
521s are overkill in my opinion, I've got these and flow and the flow are almost always strong enough
though to be fair the 521s I have are about 6 years old and look brand new so if you really are after indestructible.......
Posted : 15/11/2011 4:36 pm
This may throw a right spanner in the works but you'll soon be able to get anodised rims from Hope. They wont be offered in the 'Hoop' format that you see on all the shitebikewebsites.com so you'll have to go to a Hope Tech 'Pro' shop to get them but they don't half look sweet!
I've seen a few pairs of custom wheels come out of Biketreks in Ambleside, from experience the shop has a strong relationship with Hope so you can rely on them sorting the bits you want! I love my Ltd Edition Tech brakes!
Posted : 15/11/2011 5:08 pm
 J273
Thanks ill check biketreks out.
@Nosedive can you tell a difference weight wise between the 521's and Flows?
Posted : 15/11/2011 5:13 pm
