Hope Headset Questi...
[Closed] Hope Headset Question
[#7729249]
Trying (and failing) to find an old taper ring cover for a pre 07 headset.Hope part HS107
Anyone know if I Hopes current parts
HS125 ,and HS126 will fit ,or is there any other compatible cover anyone is aware of?
Many thanks
Posted : 25/03/2016 6:51 pm
Do you mean the top bit in this pic? Hope sent me that lot for free back in December, just needed a seal for the bit I think you're referring to. Might be worth sending them an email.
Posted : 26/03/2016 7:40 am
Hi there
Think that the new bit I'm refering to.
What I'm trying to find out is it'll fit a pre 07 headset.
Will drop Hope a line as well
Ta
Posted : 26/03/2016 12:24 pm
That is a pre-07 headset - I had the bearings & cups pressed into the frame, but I'd lost the bits pictured above, so contacted Hope on the chance they had some lying around - and they did!
Posted : 26/03/2016 11:39 pm
