The seal is on that crown race from hope matey.
You don't need a separate seal.
http://www.stif.co.uk/mtb/product/hope-tapered-fork-crown-race/11002
mosey just to check if i order that i dont need a seperate seal then? its all built in is what your saying? even better if so!
Yep the black bit is the seal.
Out of stock there mate, get it from the google link (crc) below:
http://www.chainreactioncycles.com/mobile/hope-tapered-fork-crown-race/rp-prod71610
mosey on the hope tech, it says crown race outer seal, and then crown race like they are two seperate things
if you look at the diagram
the crc one sort of all looks built into one or is it just the digram has seperated them, or is the tapered version different than the pic?
i will get it from there, ill try hope first see if they can help if not ill order it from CRC!
thanks again, i promise that last question above is the final one on the matter ha!
The pic I put on my bit earlier was the same as above, I promise you the seal and the crown race are one and the same part.
The hope tech sheet is an exploded version showing each and every part.
🙂 I wouldn't bother with Hope mate, just buy one. Technically it's the bike shop who has yours not hope.
8)
mosey you are a legend! serisouly thank you so much for the help, i will get one from the shop no sweat, thinking about the diagram hope always do exploded diagrams so makes sense!
and whats more i dont need a new bottom cup either, so its been very much worth posting the pics to you, ive gone from being confused to knowing exactly what mine has currently, and what i now need for my new forks (a simple split race for £~5!)
thanks again mosey, for patience, help and pics!
sorted!
I've had so much help from this site so it's nice I can help back.
Plus I only know because I was in the same confused state a few months back 😉
