Does anyone have instructions on how to remove a Hope Head Doctor from a set of forks?
I have tried loosening the centre screw/nut but still no movement. I have also had a look on Hopes site but can only see details on how to install one (I have tried reversing this process but no joy)
This was only installed a couple of months ago so dont think it should be "stuck" in place.
Any ideas????
what i have done in the past is unscrew the centre nut that loosens the grip on the steerer tube. Then insert the bolt into the thread for a couple of screws (without the cover plate ). Now grip the bolt and pull the whole head doctor unit out.
Don't t**t it with a hammer as I once did having forgotten that the thing screwed up tight with an allen key! That was one dead Head Doctor afterwards! 😳
What jason said....or a long screw driver with a small bit of wood up the bottom of the steerer tube and a gentle tap....have always found the rubber washer around the outside gives a bit too much grip for getting it in and out and it seems to work fine without it.
That did the job, I had tried it but with cover plate on and by hand. Shook it about a bit and it came out pretty quickly after that.
Many thanks all 🙂
