hope head doctor pl...
[Closed] hope head doctor please help
[#1705373]
never used one are these used instead of the star nut and are they any good?
Posted : 14/06/2010 10:07 pm
Yes and yes
Posted : 14/06/2010 10:09 pm
oh yes
Posted : 14/06/2010 10:11 pm
They are fine - if completely un-necessary over-engineering
Posted : 14/06/2010 10:17 pm
what Druidh says.
PITA I say.
Whats wrong with a star nut?
Posted : 14/06/2010 10:22 pm
oh god here we go - They do the job fine and dont score the inside of the steerer tube but SFN also do the same job - I prefer Head doctors but your free to use either 😉
I think the original use for the HD was for when the SFN scored the tube so badly it didn't grip no?
Posted : 14/06/2010 10:33 pm
whooooaaa be carefull. Once split a steerer tube because of one. loosened stem pinch bolts and turned bars 90 degrees for transportation in a van and crack. Maybe a little operator error but word of warning. Don't over tighten or do what I did without loosening top cap. It wouldn't of happened with a sfn. All sorted with fox warranty any hoo.
Posted : 14/06/2010 10:38 pm
They're OK, but SFN works just as well and is both lighter and cheaper.
Posted : 15/06/2010 1:00 am
 Rip
Both equally as good but a SFN is easier to cock-up on installation. Whilst it's possible to install a SFN without a proper tool, it is prone to error.
A head doctor just requires an allen key.
And don't worry if the O ring gets torn/split. It makes little difference. A tiny drop of oil rubbed on the O ring will make it easier to install.
Posted : 15/06/2010 5:49 am
Cheers guys looks like i'll give the head doctor a go on my new ragley mmmbop
Posted : 15/06/2010 9:12 am
Careful with the topcap screw, it's made of an aluminium/cheese alloy and very easy to overtighten and snap.
Posted : 15/06/2010 9:13 am
Lactic - Member
If it came with a 1.5" reducer headset it will have a stainless bolt. (Mmmbop has a 1.5" head tube.)
Posted : 15/06/2010 1:03 pm
