Has anyone managed to remove the gxp convertors from a Hope BB without wrecking their knuckles or bb ? reason being im changing to a Shimano XT chainset and would rather like to keep the bb as its new and do away with the gxp side of things , save buying a new bb as well
Yep, from memory I pressed them from the inside out
I need a set and will buy them off you if you get them out in one piece!
Mike no problem , if they pop out there all yours ,iirc I never smashed them home when fitting anyway 🙂
Cool, fingers crossed...
File a small groove into then before fitting....
Back to the future day was last week...
+1 small notch, in the past. Hope should've added one but there you go.
