Hi, I got a standard fork with 100mm spacing for the hub - also got a hope pro 2 front hub with the QR conversion fitted - doesn't seem to fit - it seems too wide (measures about 105mm). Am I doing anything wrong or do I need forks with 110mm spacing for the pro 2 hub?
Thanks.
Posted : 01/02/2009 1:20 pm
you've drifted the bearings in far enough haven't you?
Posted : 01/02/2009 1:24 pm
Can you get them the hub in at all, or will it definitely not fit?
I have Pro2 hubs and the 09 Rebas, and I find I have to slightly pull the lowers apart to get the hub in place.
Posted : 01/02/2009 1:29 pm
