Hope Freehub puzzle...
[Closed] Hope Freehub puzzler
[#5838795]
I've been running a Pro 2 Evo with a 142x12 for a month or so, but have just had a new rear wheel built so want to put this one back on my hardtail. I have swapped over the endcaps to the original qr ones(it's silver on the driveside, right???)and when putting the hardtail's cassette on (a SRAM PG90) I found the fit was very tight, and needed to be knocked on gently.
I tried to pull the cassette back off, but of course the freehub body came off with it, dislodging the endcap. I put it all back together and found that the freehub was now a bit stiff, so it all came apart and was cleaned up in case it was the grease causing issues. On the bike it fails to freewheel, causing a chain jamming effect. You can turn it by hand, but it feels too tight.
I've checked the exploded Hope Tech diagram and it's all in the right order, including spacers.
Can anyone shed any light?
Posted : 08/01/2014 11:32 pm
The rubber seal between hub body and freehub may not be seated properly.
Posted : 08/01/2014 11:34 pm
^ this. But I think the seal is plastic and sometimes needs snapping in place.
Posted : 08/01/2014 11:37 pm
It sits in the groove behind the scolloped bits of the freehub? I'll check, but I thought it was OK. There's a noticeable bit of give when you press the cassette inwards, perhaps 2 or even 3 mm of movement, in a springy sort of way.
Posted : 08/01/2014 11:38 pm
I had this with a freewheel I'd changed the pawls on and regreased. With use it freed up, but it sounds like you've checked for excess grease?
Posted : 08/01/2014 11:42 pm
End caps the right way round?
Posted : 08/01/2014 11:46 pm
Is it 'ghost pedalling' when in a stand or similar?
Posted : 08/01/2014 11:49 pm
Small washer between freehub bearing an hub body bearing on the axel missing ?
Posted : 08/01/2014 11:51 pm
This. It's always this.
Posted : 08/01/2014 11:54 pm
Posted : 08/01/2014 11:55 pm
trail_rat - Member
No, that's in place (called the barrel spacer on the explody diagram thing) although I did drop it and had to fight the spiders under the workbench to get it back.
It was the rubbery plastic seal. With the cassette in place you can't see it, but once teh cassette was off you could see it wasn't sitting properly. It took quite a bit of pressing with a small screwdriver to seat it in the hub body.
I took the opportunity to smooth down some of the marks on the freehub splines while I was at it, and the cassette drops on smoothly now. Endcaps are silver driveside and black NDS.
SO thanks very much for all your help, scotroutes got it in one, excellent service!!!
Posted : 09/01/2014 12:29 am
 hora
Which numbered item is it that needs repressing in?
www.roteccycles.co.uk/ekmps/shops/rotec/images/hope-pro-2-evo-10mm-through-rear-conversion-kit-[2]-2317-p.jpg
Posted : 22/05/2014 12:17 am
Your linking skillz are pish!
However, it's the rubber/plastic washer between the freehub and cassette. 5:15 in the Hope video.
Posted : 22/05/2014 12:20 am
