Hi will the newer style 183mm / 160mm saw tooth rotors work with the older style (Black caliper) mono mini's and mono M4's. Old rotor sizes were 180mm and 160mm.
Cheers, Geoff
Posted : 12/11/2009 10:39 am
Yes, I've used 160,183 & 203mm floating discs on Pikes & Manitous with those calipers.
But the 203mm is to tight on Mavericks - had to use the 200mm to stop it rubbing when hot.
Posted : 12/11/2009 10:46 am
Yes it should work, its only 1.5 mm at the caliper, if it rubs you might need to elongate the hole a bit. Width of disc is the same but I have had a little trouble with the bobbins that hold the disk to the ally spider rubbing on the inside of a caliper but I think that was with my shimano brakes.
Posted : 12/11/2009 10:48 am
