Anyone taken a set of these apart? I have a seal thats slightly popped out/worked loose and I want to replace it, but can't work out how to get the axle out.
Don't seem to be any videos out there and looking at the exploded view on Hopes website appears there is an M5 retaining nut, but I can't for the life of me work out how to get at it
From looking in mine it looks like you'll need a turned down socket or a narrow nut spinner, but buying one is likely to be hit n miss
If it's like all the other flat pedals I've taken apart then jam a flat blade screwdriver in there and undo from the axle end.
It's actually even narrower than usual, might still work with the correctly "just in case" screwdriver in the tool kit
Thanks, will see what I can do later
Any joy on this ? I'm just about to tackle mine. But
Sorry to hi-jack the thread, but does anyone know where you can get a cocker slim enough to dismantle a Supersat Ultra Mag, I've tried the screwdriver technique with no luck and don't have a socket slim enough.
Tom kp
A tubular socket wrench should work.
Good thinking! Haven't used one of those in years
Its a special sized socket tool from hope. Costs about a fiver.
