just put new pads in and there doesnt seam to be enough room, WHY????
Posted : 30/05/2010 10:17 pm
Pistons need pushing back into their bores? You could try that first.
Posted : 30/05/2010 10:24 pm
If they wont go all the way back you probably have a wee bit of air in the sytem if the callipers are fine then you may have to file down the opads a wee bit
Posted : 30/05/2010 10:35 pm
Very unlikely to be air unless yo have a spongy lever - the most likely is either poorly made aftermarket pads that are too thick or too much fluid in the system preventing the pistons from being pushed right back - open the bleed valve then try to push the pistons back - fluid will come out.
Posted : 30/05/2010 11:16 pm
spot on Tandem to much fluid in the system! cheers
Posted : 31/05/2010 11:10 am
