Hope Brake Spacer o...
[Closed] Hope Brake Spacer or Use Old One?
[#5007884]
Hi!
Just got some Stealth Race Evo X2's, what lovely bits of kit!, to replace my hateful Avids.
What I was wondering though is can I use the spacer on my Scott Spark to mount the hopes on, for a 180 disc, or do I have to use hope specific ones?
Also, do I need 180 discs? I mainly do Xc, with the ocasional trail centre. Although I am 6'1" and about 90Kg so pretty hefty!
Cheers!
Posted : 28/03/2013 11:51 am
What spacer do you mean?
And 180 discs will be fine.
Posted : 28/03/2013 11:58 am
The spacer that spaces the calliper out from the fork. To allow for larger discs etc. Are they universal fit?
Posted : 28/03/2013 12:00 pm
Is it currently running a 180mm disc? If yes then you should be okay. Might need to adjust the number of washers to get the right spacing.
If its running a 160mm disc then you'll need a new brake mount.
Posted : 28/03/2013 12:01 pm
It's running a 180 disc at the moment. Thanks for the help!
Posted : 28/03/2013 12:32 pm
