Hope Brake Mounts ~...
Hope Brake Mounts ~ The Correct Mounts
 P20
[#13427031]
I’m looking at hope tech e4 brakes. Fox 34 forks and Stumpjumper carbon frame. I think I need a +20mm mount for the front and the rear will be direct mount for 180mm rotors front and rear. Does that sound right?
Posted : 25/10/2024 5:46 pm
From the Fox fork set up and installation guide:
  • Pre-2022 34mm and 2022 34 SC forks use a 160mm direct Post Mount that allows you to bolt your caliper directly to the fork and utilize a 160mm rotor.
  • 2022 34mm non-Step-Cast forks use a 180mm direct Post Mount that allows you to bolt your caliper directly to the fork and utilize a 180mm rotor.
Posted : 25/10/2024 6:07 pm
P20 and P20 reacted
 P20
Excellent. Thanks for that. Serial number indicates a 21 fork.
Posted : 25/10/2024 6:28 pm
