Hi
Looking for advice regards Hope brake adapters ,I have purchased some Hope mono mini brakes (they have 3 stamped on them) now what Hope adapters do I need to run 180mm rotors ? My frame is a 2005 Orange five so IS on the frame but my forks are post mount
Would HBSM20H work ? apparently they are +20mm I assume fork and frame are 160mm
Advice warmly welcome
Number 3 calipers are for 185mm front and 165mm Rear. I’m mostly sure that’s right but been While since I’ve seen any
Thanks orangeboy so I'll need a 205 rotor for the front and a 185 rotor for the rear - good to know Cheers
Sorry ob I have to disagree look here
3 is 180 front 160 rear
so front you need a post mount to is which hope don’t do
https://clee-cycles.co.uk/P1043/product
and rear you need is to is +20 which hope do its part HBIS20
Thanks timoth, your right I was thinking mini not mono mini. Just hope the op has not ordered anything yet
