Hope braided hoses
[Closed] Hope braided hoses
[#10501676]
Are they the same diameter as the standard ones and more to the point is there any issues using them on internal routed cables?
Posted : 21/02/2019 5:38 pm
They are thicker eternally, so can make internal routing a bit of a pig.
Posted : 21/02/2019 6:54 pm
Thicker and less bendy and can get a bit of a twist on them. Look nice but I wouldn't bother again.
Posted : 21/02/2019 7:00 pm
Do people still fit the braided hoses? I had them fitted about 10 years ago but never saw any performance advantage. I should imagine on modern internal routing they would be a right pain
Posted : 21/02/2019 7:03 pm
They’re 6mm, instead of 5mm. I think goodridge do them at 5mm, without the plastic coating, but if you use that, be sure to protect your frame, as they will destroy it.
Posted : 21/02/2019 7:24 pm
