Hope Bearings
[Closed] Hope Bearings
[#2928584]
I have a 20mm front hope hub, the cartridge bearings are shot.
Bearing number is 6804RS - I have no idea what make of hope hub it is.
It just says hope on the hub itself.
Is 6804RS the same as 6804 2RS?
Posted : 09/07/2011 12:54 pm
Sounds like a Pro2 hub, & yes, the 2 bearing numbers that you've given are the same bearing.
Posted : 09/07/2011 1:02 pm
It appears to have the same bearing size as a hop 2 hub, nut doesn't have the pro 2 anywhere on it. I thought it was a bulb, but they are different in size as well.
Posted : 09/07/2011 1:05 pm
[url= http://shop.marksman-ind.com/6804-2rs-sealed-ball-bearing-20x32x7mm-1365-p.asp ]skf bearings[/url]
i get mine from these guys round the corner from me.
Posted : 09/07/2011 1:23 pm
Could just as easily be a BULB. 61804 2rs or 6804 2rs. Both mean the same thing. Actually, unless you're buying vast quantities, I've found the Hope INA bearings to be the best balance of price vs quality.
Posted : 09/07/2011 1:58 pm
Any idea of what size the circlip is that holds the adapter in place?
Posted : 09/07/2011 2:23 pm
