Hope BB Bearing Rem...
[Closed] Hope BB Bearing Removal help
[#12385055]
I'm trying to replace the bearings from a Hope BBSS30N bottom bracket.
I've done it once before and drifted/bodged the bearings out from the inside. I'm struggling to repeat the process, so before admitting defeat and buying a whole new shell and bearing kit, I thought I would consult the STW masses to see if there were any nuggets of wisdom out there?
Posted : 16/05/2022 9:12 pm
What seems to be the problem? Just a punch and hammer should do it.
Posted : 16/05/2022 9:14 pm
Ineptitude on my part I suspect. Just wondering if there are any other hacks or tools to help, or if it is a case of persistence.
I'm sure it is all fine, but just seems like a bit of a bodge for a Hope product.
Posted : 16/05/2022 9:21 pm
The shell has 2 slots to access the inner bearing race, so locate them and tap ?
Posted : 16/05/2022 9:22 pm
Haven’t tried, but I guess you could also use a bearing puller if you left them in the bike… probably wouldn’t do that with a press fit bb though.
Posted : 16/05/2022 9:24 pm
Do what binman says.
I did mine last week. It might help to clean the inside so you can see the 2 little grooves.
Line up a screwdriver and give it a thump.
Posted : 16/05/2022 9:51 pm
Dunking the whole BB in a pan of boiling water for a minute or so can make a lot of difference too.
Posted : 16/05/2022 9:57 pm
The bearing puller tool from bsc components makes removing bearings from any cups (even press fit) a piece of piss
Posted : 16/05/2022 9:58 pm
Thanks all
Posted : 16/05/2022 10:55 pm
