hope 10mm bolt thro...
[Closed] hope 10mm bolt through query
[#951209]
just bought a 10mm bolt through axle for my pro 2 rear hub,cant figure how its meant to work as the hole is not 10mm all the way through,their is a stepped down section in the middle with a 5mm(by the look of it)hole through it,how are you meant to fit a dt swiss 10mm qr/saint axle/10mm shimano solid axle through to tighten it in the frame? puzzled!
help appreciated,cheers Andy
Posted : 14/10/2009 2:24 pm
Arent some for using proper bolts in (like old crankbolt shape)
Posted : 14/10/2009 2:30 pm
hmmm, interesting. i'm looking for a new wheelset & had written off hope hubs as i thought you couldn't convert to 10mm bolt-through.
so can you do this?
Posted : 14/10/2009 2:33 pm
yes some have threads for 10mm allen bolts,but not this one,its mashined out to 10mm dead,not enough metal left to tap a thread in if you wanted to,exept for the stepped down bit in the middle(5mm hole for about 15mm)its like you have to drill/bore it all the way through to use it,that cant be right can it?
Posted : 14/10/2009 2:48 pm
Chances are you have a q/r hub axle.
Your 10mm t/a won't fit without buying the requisite 10mm hub axle and replacement bearings when the good ones are knackered bashing out the q/r axle.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=18761 ]Hub axle here[/url]
Posted : 14/10/2009 4:03 pm
I will be back with a picture.
Posted : 14/10/2009 4:34 pm
Yep you've got a q/r axle by the sounds of it.
I've just swapped my pro2 rear from q/r to 12mm bolt thru, so just been in the garage to look at the old q/r axle that I took out and its exactly as you describe.
10mm internal dia. both ends then it steps down to approx 4-5mm internal dia. around 45mm in from each end.
Looks like you've been supplied the wrong kit, are the end caps you received with it for a 10mm bolt thru?
Posted : 14/10/2009 5:01 pm
Sounds like you have a bolt-in kit not a bolt-through kit.
Give Hope a ring. They're very helpful.
Posted : 14/10/2009 5:09 pm
 igm
I've got a 10mm bolt through on mine (Hadley seeing as you asked, or even if you didn't). I had to knock the QR axle out as mentioned by Scienceofficer - note not just the end pieces like you do on the front but the whole axle - and replace it with the 10mm one as linked to.
Posted : 14/10/2009 5:10 pm
mk1fan - Member
nope he's got a q/r axle as I said above.
Posted : 14/10/2009 7:57 pm
