Hi all,
I seem to remember similar threads but couldn't find them so go easy on me please!
I am very happy with my Pro 2 Evo wheels but the rear bearings have died after only a few months. In this time they have only seen 31 rides, 33 hours of use and 272 miles (one of the benefits of using a Garmin). Clearly they have not seen much use nor am I particularly speedy if you do your maths. The rear hub felt very stiff a few weeks ago so the total time to failure is actually shorter- still not impressive.
Do Hope offer any warranty on bearings or would I just have to accept that this is "wear and tear"?
Are there better after market alternatives to the Hope bearings or any tricks to prolong their life?
Any experiences which may help me out?
Next step is to contact Hope but I don't fancy being told to bugger off by a Yorkshire voice if I can help it (sure they are very nice though 😀
Many thanks in advance, DanW
Email Hope, they should last a good deal longer than that unless you ride hub deep in Peak District puddles all the time.
Just average mud in South Wales 😀
I would try hope and see what they say.
people will tell you to open up the bearings and pack with grease but this is a contentious idea. I never do it but still have bearing bearing life in thousands of miles.
My suspension is there might be a quality control issues and some bearing housings are slightly undersized leading to bearings that fail early
Incredibly bad luck.
Hope bearings usually outlast their owners, who have spent most of their rides laughing at owners of shimano hubs, which usually disintegrate within minutes
Where is a decent place to get replacement bearings while we're vaguely on this topic
(thanks OP for this minor hijack 🙂 )
I get mine from a local engineering supplies place. Anywhere that sells decent quality branded bearings will do
My first set lasted only about 6 months, though i've no idea what that meant in terms of miles, on that bike. For comparison of conditions, I had a Shimano BB fitted at the same time and it lasted better 😉 Second set is doing a bit better. They are pretty small bearings and though the sealing's not bad, it's not amazing either.
My Shimano BB has lasted for roughly 2 years and is still going strong which is what makes me wonder if the rear hub bearing failure is a little premature...
No worries on the highjack dirtbiker100! I would love to know where to buy the best after market replacements too 😀
I did a couple of thousand on my Evo hubs last year, still smooth. Do you use a pressure washer?
just bad luck, mine usually last 18 months at least at a similar use rate as yours
are you totally sure its the hub? just asking as I once had to apologise to the guy at just riding along after pestering him about a hub wearing out really quickly, turns out it was my frame bearings make things wobbly at the back, the hub was fine
I had a similar problem with a Pro II rear hub. It would seize after only 2 - 3 rides. Each time I would replace the bearings and it's be fine...for 2-3 rides. Drove me mad. I spoke to Hope (Lancashire not Yorkshire - how very dare you!) and they suggested I sent it in. Which I did and they replaced the hub free of charge. I think the suggestion was that a small % of hubs are marginally too wide and this allows water ingress. Either way, I trust Hope kit and the aftersales was excellent. I have lots of other Hope hubs with no bother. One piece of advice I was given: how far can you push the bearings in by hand? If significantly then the hub may be a problem.
Yes definitely the hub bearings. They barely spin in my hand and it got so bad on the last ride that the hub end caps are trying to rotate in the dropouts and wearing the end caps/ dropouts- not good for keeping QR tension either!
No pressure washer, just a brush and soapy water as I am not posh/ lucky enough to be able to avoid the extra elbow grease.
Sounds like bad luck then
Thanks Will, I will have a go by hand before contacting Hope. Great advice, thanks
I've just had to replace mine after 7 months, although having felt the difference between new & old, they've been in a bad state for at least 3 months. IMO changing the drive-side spacer design to reduce drag has led to poorer sealing. I've had the freehub off after a particularly wet trip to Wales & found water inside.
Before you buy new ones, knock them out to find out which are gone. My drive-side S61903 and the S17287 and middle S6803 were all rough as ****. The remaining S61903 & S6803 were as smooth as the new ones. UKBikestore sell them separately, but they're not cheap. Expect to pay £40 for a full set.
4 months isn't very long and hope's bearings are good quality most of the time INA or SKF, any chance of a photo of the bearings if you do decide to service it yourself of before you send off the hub?
Sounds like a warranty issue to me and having dealt with Hope several times I'd reckon they'd be wanting to accomodate you and sort it out.
I get at least a year to two years out of mine...pawl springs tend to go first.
Someone was talking about stiffness in the rotation...you have to watch the non driveside seal for that...put too much grease on and the wheel won't freewheel or turn well
my pro 2 bearings only lasted around 6 months, contacted hope they said the new ones would cost £x.xx (rrp).
then around 6 months later i had a single replacement bearing fail catastrophically damaging the axle, and leaving me trying to descend ther nutcracker in lustleigh on a fixie!! i ended up replacing axle & 2 bearings also when i opened it up all the pawl springs bar one were fubarred too so they got replaced at the same time, no offers of help from hope they just told me what rrp was on replacement parts, fair enough i guess but i certainly didn't get the famous customer service everyone else speaks of on here (must be my westcountry accent).
never had any other hubs fail like this.
try the Enduro 17287 abec 3 bearings from [url= http://mbbearings.co.uk ]mbbearings[/url]
What bike have you got ?
Is it standard QR ?
Only asking because some frames seem to load bearings more than others some will even snap axles just curious as the usage your stating seems very low for them to be worn out...
You mean like a bent drop out?
No I mean some frames seem to load bearings and axles more than others
Something might be an issue frame wise which can lead to premature bearing wear
We've had some issue's with some marins snapping the axles in pro 2 hubs and hope will make a steel axle when I phoned and said we had a customer who's broken 2 axles they actually said does he have a Marin if so he needs a steel axle.
My point being there could be another another cause for premature bearing wear especially if the next set lasts a similar period.
Fingers crossed you've just been unlucky.
Are they Marins with rear maxles? Pro 2s didn't play well with with maxles- lots of issues especially with maxle lites with the taper, since the Pro 2 maxle axle is paper-thin. (it's just the same as the QR axle, with a bigger hole through the middle)
I did smell that.
I'd call hope my pro 2 hubs seem to go on forever mate.
Well, with everything taken apart the bearings in the hub shell seem fine but the bearings in the freehub (particularly the drive side) are stiff and squeaky. I would imagine it is these that are causing the issue. I will take it to the LBS for a second opinion and see what Hope say...
Bike is a Santa Cruz Superlight
drive side freehubbearing seems to have a hard life and fail the most easily
I'd definiltey say bad luck, i put Pro2's on my bike a year and half ago, out on my bike 3- 4 times a week in Bristol then probably once a month in wales, including downhilling at Cwmcarn and i'm a fat bast*rd and the bearings are still as good as new
you don't spray GT85 or equivilent on the hubs after cleaning do you? i've been told that stuff will take the factory grease off shortening the life, so just spray with water and brush off to clean, leave evrything else
No nasty spray or pressure washing. Just soapy water and a brush for the regular post-ride clean.
the bearings in my Pro2 rear went in <15 rides, which was disappointing. The replacement set have lasted better though.
Mine have gone at the mo. As a bonus the freehub has seized onto the axle. Hope have said to get the wheel to them and it will £22 + postage back. Not bad I would say.
Hop Pro 2 rear hub bearings dead after 4 months :/ Just bad luck?
Have a search through my previous posts.
**feeling smug** 😉
You running shimano Peter? 😉
Actually no, not 100%. But if I was buying new, I proably would get XTs
I have:
1 Pro 2 (Front) which eats bearings regualrly.
3 x Hope XC (2r, 1f) which are waaaaaaaay better lasting
2 DT Swiss 240 which are too new to pass comment on
A couple of old Shimano/unbranded C&C hubs which go on and on and on and on
A DT Swiss Onyx which eats cheap bearings but seems a lot better if I pop the seals and regrease before I fit
Mrs PP has
2 Pro 2s. Which are shit. Utter shit. The bike uses more hub bearings than it does brake pads (Serious) and one of the flanges broke off
2 Shimano 475s, which get a bit rough fairly quickly but then never get any worse and it doesn't matter becasue they are so cheap
I've got my bikes sorted now, I think I should go about getting Mrs PP some decent wheels.....
EDIT
Oh, and something just a little bit special, wheel wise, for my next bike which has been on a slow burner for a long time now, and will also be a little bit special itself 🙂
Hubs are back from Hope having had the hub shells replaced but they still only spin about 2 or 3 revolutions before coming to a halt. This stiffness occurs when rotation is around the axle so it is not pawl drag 😐
Is this normal for hub rear hubs? Is this the best I can expect them to be?
This is the thread I started: [url= http://singletrackworld.com/forum/topic/hope-pro-3-hub-problems ]Hope Pro 3 hub problems[/url]
Seems like the new design isn't as good as the previous one.
It's taking a long time but it looks like Hope are sorting mine out under warranty. The bearings are worn too.
How do you guys manage that? My hope pro III set of wheels have gone through hell in the last 2 years and I barely have to true them. The bearings run as smooth as they can in spite of the constant enduro racing, shuttle days, lift days and general thousand of altitude loss they have gone trough.
No idea Juan! Mine were great for a few weeks but have never spun smoothly since, despite being returned to Hope under warranty.
I have heard stories of inaccurate machining on some batches and all sorts of other things which may at least partly explain the problems.
Anyone else have stiff rear hub axles even with new bearings?
TandemJeremy - Member
No surprise really as the drive side lacks the seal that the non-drive side has - design flaw?
My Pro II SP's have officially lasted 2 years but I am a regular fettler and usually overhaul my bike after every winter - The bearings are running rough but still spin well.
I think Hope hubs are like Landrovers - good at what they do, spares readily available and they go wrong/wear out more often than you think - but they are easy to fix.
The pawl springs seem to be an annual service item.
EDIT
Could never figure out why they didn't include a drive side seal.
Yeah I can't believe the sealing on Hope hubs, given they are British.
DanW, if you are out on Saturday let me know and I'll take a quick look then and see if I can shed some light on it.
Steve(your friendly LBS)
Thanks Steve, I think I'll pop them along to you. I was hoping they would come back from Hope absolutely perfect but I'm not convinced that they actually are.
I'm a massive fan of Hope hubs - good tough British design!
However, i was gutted for some guy from St Helens who i met at the top of Jacobs Ladder on Sunday with a split Hope hub
That is one hill i'd hate to have to walk down!! 🙁
