HONC route availabl...
[Closed] HONC route available online?
[#2618893]
I see last year's HONC route was available online in advance, anyone know if the same thing's going to happen this year?
Posted : 31/03/2011 8:37 pm
I emailed them last week and apprentley they will be publishing the gps routes in the week before the event
Posted : 31/03/2011 8:41 pm
 mrmo
grahamh will be along at some point i suspect, but it is usually made available a little before the event, say a week or so.
Posted : 31/03/2011 8:43 pm
Sunday or Monday..
Depending on when it gets uploaded.
Posted : 31/03/2011 9:46 pm
Graham, is it waymarked again this year?
Posted : 31/03/2011 9:48 pm
Yup, big yellow and black arrows..
Posted : 31/03/2011 9:50 pm
Thanks all, look forward to checking it out.
Posted : 01/04/2011 8:44 am
http://www.winchcombecc.org.uk/honc/route/HONC_11_long.gp x" title="BIKEHIKE.CO.UK" rel="nofollow" target="_blank" >
BIKEHIKE.CO.UKBIKEHIKE.CO.UK "http://www.bikehike.co.uk/mapview.php?lnk= http://www.winchcombecc.org.uk/honc/route/HONC_11_long.gp x"
http://www.winchcombecc.org.uk/honc/route/HONC_11_short.gp x" title="BIKEHIKE.CO.UK" rel="nofollow" target="_blank" >
BIKEHIKE.CO.UKBIKEHIKE.CO.UK "http://www.bikehike.co.uk/mapview.php?lnk= http://www.winchcombecc.org.uk/honc/route/HONC_11_short.gp x"
Posted : 05/04/2011 11:34 am
Thanks for the link.
I downloaded the route to my Garmin 305 last year and only got half of it.
I think there's a setting somewhere on my 305 for the maximum number of waypoints. This event is the only time I ever follow a downloaded route, so I'm not familiar with how to do it.
I know I could RTFM, but can someone give me a quick guide on how to get the route from that map to my GPS so I can follow it on the day.
Posted : 05/04/2011 11:49 am
Download the GPX and then convert to a crs file using this converter http://www.gpsies.com/upload.do?uploadMode=convert
Then use Training Center to upload it to the GPS.
You then follow it using the training menu on the Edge.
Posted : 05/04/2011 11:52 am
That sounds more complicated than I was expecting.
I just downloaded the route as a GPX file direct to my 305 and got a screen message saying "Route Truncated".
I'm sure I've seen something somewhere about maximum number of waypoints being set to 200, but I can't find it now.
Isn't that all I need to alter ?
Posted : 05/04/2011 12:09 pm
It isn't really.
Converted short and long course files for you here:
http://dl.dropbox.com/u/2154559/Honc_11_long.crs
http://dl.dropbox.com/u/2154559/Honc_11_short.crs
Posted : 05/04/2011 12:32 pm
Anyone got a copy I can look at without a garmin...
Posted : 05/04/2011 12:36 pm
I think I've got it. I was getting confused by Routes and Courses. I still don't know what the difference is, but I seem to have saved it as a course.
I've also saved it on to my Memory Map 3500, which was a challenge in itself. MM don't make it easy to transfer stuff from the device to the PC and vice versa.
Posted : 05/04/2011 12:48 pm
A track is lot of points very close together like a breadcrumb trail, recorded as you are riding along usually.
A route is a list of way points used for navigation. There are much fewer points than a track, as you tend to only put waypoints where you need to make a turn.
A course is a route with time additional training information added. You can navigate a course - just ignore the speed information.
Posted : 05/04/2011 12:52 pm
Yep.. click on links DoctorRad gave out
DoctorRad - Member
Posted : 05/04/2011 12:54 pm
Thanks Geoff. I understand tracks as that's generally all I ever use my Garmin for, to record my rides. It's Routes and Courses that are new to me.
I might have a go at saving a previous commute as a Course and following it to work this week to familiarise myself with it all.
Posted : 05/04/2011 1:01 pm
Good idea.
Trickdisco, cheers. I just clicked on the long one in error, nearly had kittens.
Well at least it's not too flat..............
Posted : 05/04/2011 7:26 pm
Intermediate route: follow long route to around 45km then pick up last 20km of short route = ~65km.
Longer intermediate route: follow long route to tarmac @ 55.8km, turn left instead of right, then pick up end of short route.
Posted : 05/04/2011 10:06 pm
Does the long route go clockwise or anti-clockwise as I can't tell?
Posted : 07/04/2011 9:11 pm
